We value your input!
InsulFib Object From ArchiCAD Library
The InsulFib 2D object works great for representing insulation when drawing details for construction.
However, this object cannot represent insulation that is wrapped around a curved or circular form, like a circular column, for example.
Is there a variation of this InsulFib object that can curve?
Anyone has this object? Please? Thank you!
This one ("Insulation - curved.gsm") is from Olivier Dentan´s page:
http://archilib.od.pagesperso-orange.fr/index.html
Draw insulation fill with lines and curves
copy
open line types and create a new symbol line type
paste in lines and curves
now you have a line type that can curve, straight etc!
Trick is to adjust dash length to scale 'thickness' of insulation to desired size.
Once set up for various thicknesses it is a real timesaver.
