Interior Elevation Cut Objects are not correct
The image on the left is what we get with interior elevations, and the image on the right is what we want. I've put fills and lines on the right image to achieve the correct look - but is there a way that archicad will produce it for me instead?
11 REPLIES 11
Erika Epstein
laszlonagy wrote:
Erika,
I will let the guys at GS know about this Cabinet thing.
Thanks!
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Erich
Sam,
Perhaps Laszlo's suggestion fixes things for you. If not I have attached the mask object (AC 11 USA) for you to try. If it works for your needs...great. In addition to masking interior elevations it can also provide a consistent outline for each elevation, space your notes, and ease layout on your sheets depending on how you set things up. There are notes provided in the UI.
I wouldn't mind hearing how others deal with interiors in their work flows. It seems to be a serious week spot in the documentation tool at they currently exist.
BTW you should create a signature with your version of AC,machine specs., etc. It can affect the answers you get.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
