Interior Elevation Marker Head -- rotate?
Geof Gainer
Can I get the marker head to rotate in an IE? The way the text is split reads a bit backwards. How about hiding or changing the cut line type?
AC fan since v 7. Currently on AC 26 Build 5003 USA FULL, and AC 28 Build 3110 USA FULL, Apple Silicon,. 2022 Mac Studio, 32G ram. MacOS Ventura 13.7
4 REPLIES 4
Erika Epstein
On the marker tab there is a setting Marker Text Rotation where you have 3 options. Will this do what you want?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Geof Gainer
Oop! -- I must have looked right at that thing. Thanks.
Any way to hide or change the line type?
David Maudlin
Geof:
These lines are an On-Screen Display Option, so they won't print, and can be turned off by disabling Marker Range. Their line type and pen are set under Project Preferences > Miscellaneous: Line Type and Pen of Markers Elements' on-screen-only parts.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Geof Gainer
Fantastic -- would have taken me a while to find that one.
