Interior Elevations
How do I turn off the lines on the elevation marker that show up in plan view to indicate what is being elevated? Is this even possible?
Thanks
4 REPLIES 4
If you are referring to the lines on plan that indicate the area that the elevation will capture, their visibility is controlled by the 'marker range' on the 'on-screen view options'.
As the name suggests, they are an on-screen only option and do not print regardless of the setting.
It is useful to note that their linetype and pen is set in the project preferences, in the miscellaneous section.
Rod Jurich
alexandria wrote:
/..... Is this even possible?
Attached pic shows 12 menu.
Please add a signature w/OS & AC version.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Rod,
No matter how many times you post it, I still beat you!!
Rod Jurich
Technology don't you love it. You send and the browser shows as it is still underway.
When trying to rectify it appears that it has gone and more than once.
But you only discover this when revisiting the original post.
And you no doubt are younger and dare I say quicker on the keyboard
Rod Jurich
