Internal wall goes into exterior wall
Hi People,
I am learning ArchiCAD at school and doing assignment at home. The interior wall I drew goes cross and goes on top of the exterior wall, I have clicked on the inside line of exterior wall but it starches to the outside line. Does anyone know how to fix this?
Thanks
Johnny
Hello,
You have used a material which is intended to be used for thermal insulation from the outside of the building.
Did you try to select these two walls and then go to the material library to check all their material priority ?
I advise you to duplicate the material you want to modify instead of modify the original material.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
