Learn more
Intersecting Complex profile beams
Hi all. This may have been asked before, or is actually quite easy to do...
But I having a bit of trouble whilst trying to connect two complex profile beams. What I'm modelling is a overhang, which has a slight pitch to it and tapers into a curve. Easy enough for the straight sections, But as soon as I get to the corners they intersect each other and stick out.
I've been fiddling with the solid element operations but im not having much luck.
Anybody have any ideas?
Thanks
2 Replies 2
Thomas Holm
Try using the complex profile with the wall tool instead. It should join correctly at the corner.
An alternative would be to use a complex profile for the curved edge only, and the mesh tool for the rest.
Ah ha, using the wall as the complex profile worked. Not sure why I overlooked that. Must be because its late in the day! Ready for home now!
Thanks a lot!
