Intersecting Shell Roofs
bennerm
Looking for a solution to intersect two curved roof forms, similar to a hip structure. I have created two shell forms. Now I need to "trim" off the parts of the shells that are above the desired roof form. Any guidance would be greatly appreciated. There is a link to a view of the model to help illustrate the condition
MacPro
AC 23
I haven't tried it, but can you Split a shell along the intersection line? If not convert to Morphs and Split the morphs.
bennerm
Thanks, good suggestion. The shell didn't split, but the converted morph did.
MacPro
AC 23
Hi, Probably is a little late, but this could help you, at least for the next time.
https://youtu.be/4wWDi31-Lw0
