Intersection numbers in Layers panel
For some reason I cannot figure out, the intersection numbers I have used to keep certain walls from intersecting continue to revert to "1". It doesn't seem to matter what I do in terms of saving, exiting, re-opening, etc.
Is this a bug or does someone have a fix for this.
Thanks,
This number is used with Layer combinations. You can assign different number for each layer combination.
...and don't forget to press the "Update" button when you are done adjusting the layer combo. Even after fifteen years of using ArchiCAD I still make that mistake.
