ā2007-04-12 03:38 PM
ā2007-04-16 10:56 AM
Djordje wrote:It should work to connect the roofs, just not to remove the unneccesary parts.Link wrote:No, but trimming along a known intersection line is OK, as long as you don't care about the roof edges angle.![]()
Can't you just select the entire main vault and ctrl/cmd click the edges of the other vault?
Only CTRL clicking each of the intersecting toof planes gives the correct result, as does the Composite profile approach - then it is probably a beam or a wall, not a roof ...
