I have created a site mesh which is clearly visible in the 2D view, however when i switch to a 3D view the screen is blank. However I can select the mesh and the corners and the other nodes appear as dots, but that is all I can see. If I hit esc then everything is blank again. I have all layers turned on, and everything is as I always have it. I have attached a screenshot to illustrate, the blue lines are the perimeter shape (at 0), while the black dots above are where the surface of the mesh should be.
Any suggestions appreciated.
	Using ArchiCad Start 2020 On PC With Ryzen 5 5600 6 core, 16Gb Ram, 64bit Windows 11, Nvidia RTX 3060 Ti, 32"; Lenovo Monitor; 1920 x 1080 Res
