Is it possible to have a zone's ID showing on plan?
I'm using zones for an existing site survey to achieve lists / shedules of housing types, streets, numbers, ... and other data.
I would like to represent the different housing types (=ID) on plan without tweaking f.e. the flooring parameter...
If possible, can I get User Defined input (from the Parameters for Listing tab) as well?
Thanks
With a bit of GDL scripting you can do it.
The script of the Zone Stamp defines that types of data that can be shown, that is what needs to be modified, I believe.
