2012-04-1807:56 AM - last edited on 2023-05-2505:02 PM by Rubia Torres
Is it possible to select more then one node in mesh tool
2012-04-1807:56 AM
Is there a way???
it sure would be handy when amending mesh levels. more often than not i want to select more than one node (but not all nodes either).
thanks
jakub
ArchiCAD 10 - 25 | Windows 10 ARCHIcreate | Perth, Western Australia archicad solutions | content creation | training | software implementation
AFAIK you can only select together all linked nodes created in the same Mesh Line. With Mesh Lines you can use the 'Apply to All' button when adjusting Mesh Point Height. It will apply to all points on the same line
