Is some kind of a demo of AC12 avaible for download?
My company wanted to buy Archicad and now we dont know if its worth waiting for a new version in Poland or its better to buy Archicad 11 with all hotfixes.
I've found only MAC version, but we are using PC's.
Is there a place where I can download some demo or trial?
greetings
Szymon Gozdzikowski
5 Replies 5
The commercial version when run without a key will run in demo mode (everything works except save as I recall - you can even print). Your dealer may be able to give you a copy.
__archiben
yes, here:
https://trialregistration.graphisoft.com/
~/archiben
b e n _ f r o s t
I just tried this and it only has Version 11 available for download so far.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
Link
The demo mode should do everything except Save, Copy and Teamwork. It warns you of this as you use Demo mode and a warning will remain there while you work.
GS probably just hasn't gotten around to updating the trial version yet.
Link.
Demo versions come out not very long after the initial version release, so it should be available shortly.
