Mats_Knutsson
Mentor
Is there a way to find incremental gaps inwall connections?
I'm trying to "mend" a model that is ever soooo slightly off almost everywhere. Firstly it's rotated 0.0029 degrees and I suspect someone has been working with slightly off grid lines. ArchiCAD is happy but the MEP on Revit is angry as **** when Revit complains about not being able to create Rooms from the IFC-model.... I'm talking gaps in fractions of mm....freaking nightmare.
Is there a way to find gaps like this? I've got Solibri but I don't know how to create a rule for checking "wall end"-"wall line" connections.
/Mats
AC 25 SWE Full
2 Replies 2
Eduardo Rolon
Mats_Knutsson
Mentor
ejrolon wrote:
Read here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=55020&highlight=element+orientation+check+cheque
and here
http://www.bim6x.com/blog/fixing-untrue-models
and here
http://archicad-talk.graphisoft.com/viewtopic.php?t=55048&highlight=element+orientation+check+cheque
Yes thanks .
The problem is already created. I'm trying to figure out if i have to remodel or try to adjust.
AC 25 SWE Full
