Is there a way to...
I have a building that I'm working on for a Uni project. I have drawn surrounding buildings that are just very simple boxes with roofs basically.
In section view, I want the main building to be cut but surrounding buildings not to be cut at all ( if this makes sense ) whilst still being able to view all buildings in one section view. The reasons is, I don't need to see inside the other buildings ( as they are empty ), only the main building ( that I've designed ) but I also need to keep them al in the same section.
See the attached for a view of what I mean ( I know the roofs are messed up, I didn't have time to do them correctly, but they will be soon ! )
Thank You this is very important to me !
5 REPLIES 5
Dwight
Stagger your section cut.
Dwight Atkinson
That sound like it will do the job ! I'll check the manual, Thank You
P.S Please could you check my other post about translucent glass please ( I make work I know )
Can I stagger a section cut that has already been created ?
The manual shows that you select straight or staggered line before making the cut...
file:///Applications/Graphisoft/ArchiCAD%2013/Help/Files/wwhelp/wwhimpl/js/html/wwhelp.htm
Thank You
Thank You
Yes. Select the Section line, pick and drag the centre node and use the top-left button on the pet palette that pops up.
s2art wrote:
Thank You
When I do that, I can only move it about the centre of the line... How can I change that ?
EDIT: Never mind, I found that you can alter it by dragging it...
Thank You
