2008-09-0403:27 AM - last edited on 2023-05-2603:09 PM by Rubia Torres
2008-09-0403:27 AM
Does anybody know how to join slanted walls (with parallel surfaces) with perpendicular (straight) walls. Please see screen shot. I can get one wall to join, on the left, but not the one on the right. Is it a wall priority thing? I have tried having the walls start at the same height and increasing the priority of the slanted wall but nothing seems to work.
How did you create the sloping wall? Did you set the Wall Complexity to slanted in the Wall Settings or did you use a Complex Profile?
You should have more luck with the former method, but the wall intersection priority numbers will have to match and their reference lines will need to intersect, as always.
Slanting wall made in wall settings and reference lines intersect. The reference lines change at the correct end to mitre properly but at the other end they dont mitre properly. Same lines, fil, etc, in each joining wall.
I have included a plan shot of the wall. The walls go right through and connect with the outside reference lines of the intersecting walls but only the one on the top of the page connects properly. Strange.
