2022-01-11 01:02 AM
Hi guys,
Newbie here.
Is there a way to off centre the downpipe hole in the K gutter profile so that it's not cutting through the angled portion of the gutter and along the flat base of the gutter?
Thanks in advance.
Solved! Go to Solution.
2022-01-11 04:07 PM
If there is not a setting, then either edit the code or convert to a morph, or draw it in separate.
I used the railing tool for all of my gutters and Eave items since it links to The roof notes but if you edit things correctly you can use a post as the downspout which gives you a decent amount of control as to the placement.
2022-01-12 02:37 AM
Thanks for responding Seneca. I'll give it a a go.
2022-01-12 04:40 AM
custom profies also work... or for that matter, just turn the downpipe hole off and place the downspout where you want it... nothing says you need to show a hole in your gutter to connect a downpipe (unless you are doing a rendering of your gutters! 😉 )
2022-01-12 05:20 AM
Thanks for the response 4dProof.
2022-01-12 09:08 AM
Let me know if you want a sample file.
