We value your input!
Label Angle in Elev
G.S.
Placement of label in Elevation bug?
When I tried to to get label to turn at 90 degrees, in order to have it read right side up it won't, unless the angle is changed to something more than 90, as in attachment.
It only took adding .1 to 90 degree angle but without that added amount it won't read right. It reads vertical!
Bier
Gets even better!
Maybe I should go study my trig some more, I'm apparently very confused
about some angles here. Should I use the Law of Sines or the Law of Cosines to set the right angle for my label?
Bier
Go Archicad!
vfrontiers
ZERO doesn't work?
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
Thanks for you reply Duane.
One would hope so,
But,,,,NOPE...
It's late, I shouldn't even be out here in my "cave" so maybe I just need to be smacked on the side of the head, (with a soft mallet please)?
But 90 is what I tried after zero "0" did not work, and this is what I get for
being newbie after 3 yrs!
P.S. Up to 91 also works because I don't think most folks would notice a 1 degree out of plane. At 92, maybe??
Bier
