Label of Column
ratnabhirud
Hello Everybody,
I am using Archicad 14 and working in Feet & Inches.
I want to get label of Column & Beam in the same working unit system.
Right now seems in Decimal System.
Does anybody know the solution?
Thanks & Regards,
Ratna Bhirud
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
6 REPLIES 6
Steve Jepson
do you have a custom lable for this ?
ratnabhirud
Thank you Steve Jepson for your reply.
Here is the settings what I had done for the Column Label.
Attaching image for the Column Label setting
1) Project preferences - Imperial
2)Column Label Setting
Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
Steve Jepson
It depends on the label but here is how it is done for this column label.
You may need to add some script to your label if you want to have more control of the dimension display.
I don't have a good custom label for columns. Perhaps someone can share one with us??
ratnabhirud
Thanks Steve,
But I don't know scripting.
Actually I want to learn GDL Scripting.
as per your attached image,
How
(col_marker(V 10) in 'Content and preview" &
'Accuracy' in 'Symbol Label' came.
Can you help me?
Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
Steve Jepson
Attached is the column object I found that has the settings you would like for display of column dimensions.
What I do some times is open an object, find the script I want, copy it and add it to another part.
If you send me the column label you want to have this "Accuracy" script added to I will give it a try and see if we can make the label you want.
Have you looked here for labels ?
http://archicad-talk.graphisoft.com/object_depository.php
Also if you want to make your own new Label there is a template of sorts for that. Click File-Libraries and Objects-New Objects. Then click on the Select Subtype button. Expand the Drawing Symbol tab and select Label. Click Select. This will get you started with the basic label.
You can open another label or object at the same time. This way you can see them side by side. Use drag-n-drop to copy script from one object to the other to make a custom object with out ever knowing any GLD. All you need to know is how to copy and paste script. Doing this is not a bad way to get a basic understanding of what GDL scripting looks like and how it works.
ratnabhirud
Thanks Steve for your valuable reply.
I will try my best for this but it will take some time.
I have downloaded zip file.
Thanks & Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
