ā2023-03-14 03:34 PM
Hi everyone,
I am currently working on a package of drawings where the same label goes on multiple plans/drawings. I would like to set up the labels so that when I change one, the other plans will change too. Any suggestions on the best way to do this would be much appreciated.
Thanks in advance.
ā2023-03-14 04:12 PM
Try to be a little bit more precise on what you want to achieve (maybe some images). You'r talking about plans/drawings shall the label be placed on plan vues in the model or on drawings on MP ?
What kind of informations shall it display ? .....
ā2023-03-14 04:32 PM
Hi Bruno,
Thanks for your quick reply.
The labels are for building regulations so they include info for wall build-ups etc. I would like the labels placed on the layouts.
For example, I have a label for eg. a partition wall that will be required on both the GF and FF plans. I have placed the label on the GF layout and FF layout. Is it possible to connect them so that when I change one, the other automatically changes too? I think this would save time in the long run if for example, the wall finish changed later down the line - I could just change the label once instead of going through each layout and changing each label individually.
I hope that made more sense
ā2023-03-14 04:50 PM - edited ā2023-03-14 04:50 PM
Place the label on a worksheet then create a vue of this worksheet that you place as a drawing on all MP that you want. Modifying the label on the worksheet will cause all all placed drawings of it to update.
ā2023-03-14 04:56 PM
Thanks, Bruno! What do you mean by create a vue of the worksheet and what are you referring to when you say MP? Sorry relatively new to the archicad world.
ā2023-03-14 05:14 PM
Sorry MP is a french abbreviation for layout. Create a vue is the normal way to place a drawing, from the model or a worksheet, on a layout.
ā2023-03-15 10:21 AM
Thank you Bruno!
