Layers in Archicad - a pure hell
cocoloco
Hi!
Not to start negatively or offensively, but Archicad layers and its setting is a pure-outdated-hell.
I have an issue with layers... I have all items precisely set up in layers, yet, if I click on floor plan and choose furniture (Furniture dwg is my layer for furniture) BUT when I click on furniture (chair) it also select all different layers, basically full house... See print screen. If I go to layer setting I have to make visible all the layers it made invisible in the floor plan. I know it sounds confusing... and it is.  Anyone please having solution? Maybe its something in setting that I am not aware of setting up?
undefined
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
mikas
It seems to be a group you selected, or a block like in AutoCAD vocabulary. Your screenshot is too small to see of you have groups suspended or not. Try that. If you need to select all elements on a spesific layer, you can use Find and Select -function. Or, just show only that spesific layer and just then command Select All.
But then again, to your first statement..
Layers in Archicad are certainly not the most functional part of the program. For example you should be able to shut/hide/lock/unlock layers from any program menus too, from any of them, and not just only from Layers modal window.
That might be coming soon though, not sure but they are doing a lot of user interface changes to AC26 according to sneak peak they just gave us couple of months ago.
AC27, Rhino7/8+Grasshopper, TwinMotion • Mac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
Thanks for sharing, its very insightful! so "Suspending groups" partially fixed the issue. Now, I click on let's say "chair" and it select only chair and group
furniture dwg" which is correct. It works for this situation, but I don't think it solves the issue because now I can't select "all furniture group" but just one chair...  I believe there was a shortcake Cmd+A but it selects everything and not just a group. Would you know about other shortcut only selecting group items/type of items please?
As far as the Archicad updates... I am super excited and they should definitely improve many things like even easier way to switch between imperial and metric system.... Considering that they do update only once an year this all should be already done long time ago, if not at the born of the software.
Gerry Leonor
to have a more powerful way of selecting specific things, you can use the Find & Select command. (Ctrl + F is the default shortcut, i believe. i have mine different). with this, you can narrow down exactly what you're looking for using whatever type of element they are (2D, 3D, wall, line, circle etc) on what layer they're on, & many other criteria.
also, it's best to suspend auto-groups if you want to use Find & Select. otherwise it'll also select all other elements in same group no matter what criteria they have.
AC25 | Win10 | 64Gb RAM | Intel i7 13700F | RTX 4070 Ti
https://discord.gg/XGHjyvutt8
