Layout Book Pages seem to be Locked?
Not sure how this happened, but I am now unable to do any work on my layout book sheets.
I can't select any of the drawings, nor can I add any text, lines, objects, etc.
IS there a key I may have accidently hit that triggers this?
9 REPLIES 9
just a guess .. is it possible that it is on the master layout ?
No its actualy drawings that I have placed on them (over 50 sheets, multiple drawings per sheet) and that I have freely moved around up until about an hour ago.
Further, I can't add anything to them, such as text, lines, fills, etc.
And it's a .pln file, not a teamworkfile?
Thomas Holm
Check that you haven't turned on Grid Snap (S key)
It is a teamwork file, but I am signed in as the Team Leader with Exclusive Access and have been since before the problem started.
Sounds like a bug or something like that if you have logged in with exclusive rights.
First, check Thomas Holm's tip!
Then:
You haven't split layouts from projectfile?
What icon do you have in front of your layout? Could you take a screenshot?
What happens if you create a new layout, is that locked too? And if not, is it locked when you sign in next time?
Seems to have been just a bug.
I shut down my computer and restarted it and now all is fine!
Thanks for the reply's.
Your snap was on.
Well, I have been using  Archicad for years and so it surprised me to find a problem I have never experienced before. So I basically could not adjust adjust drawings in layouts. After long time of trying and googling, your advice helped!
Cheers!
S.
