Line Direction
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-11-19 10:44 AM
2008-11-19
10:44 AM
It's a pain when the adjust command adjusts the line the other way..
Thanks
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-19 01:58 PM
2008-11-19
01:58 PM
the adjust command isn't influenced by the line direction if i understand your problem correctly... if you're adjusting a line to be smaller that what it was, and the left over segment that you want to keep is smaller that half the original line, then the adjust will not work like you want it to: it will make the line smaller but it will keep the longer side. use trim or split and delete?
i might be way off with what your problem is though... can you elaborate?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-19 02:10 PM
2008-11-19
02:10 PM
fields:
I am guessing that you are using a symbolic type line (a screen shot would help) that has a pattern, and you want to switch the end of the line where the pattern starts. You could mirror the line, perpendicular to its direction, on its midpoint.
David
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-20 01:20 AM
2008-11-20
01:20 AM
I agree, mirror or even rotate command
but... why?
but... why?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-20 05:09 AM
2008-11-20
05:09 AM
There is an option to change the direction of walls (Design >Modify Wall); it would be good if this was available for lines as well.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Mac OSX 10.11.1
AC5-18
Onuma System
