Line Direction
Hi, I know this is a pretty simple question but I cant seem to find any answers for it. How would one switch the direction of a drawn line besides redrawing it manually the other way?
It's a pain when the adjust command adjusts the line the other way..
Thanks
4 Replies 4
the adjust command isn't influenced by the line direction if i understand your problem correctly... if you're adjusting a line to be smaller that what it was, and the left over segment that you want to keep is smaller that half the original line, then the adjust will not work like you want it to: it will make the line smaller but it will keep the longer side. use trim or split and delete?
i might be way off with what your problem is though... can you elaborate?
David Maudlin
fields:
I am guessing that you are using a symbolic type line (a screen shot would help) that has a pattern, and you want to switch the end of the line where the pattern starts. You could mirror the line, perpendicular to its direction, on its midpoint.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I agree, mirror or even rotate command
but... why?
Erika Epstein
There is an option to change the direction of walls (Design >Modify Wall); it would be good if this was available for lines as well.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
