Line weighr of roof lines in plan
How can I change the composite roof line weight in roof plan. The option is not showing on floor plan and section display. I attached a snip
Kind Regards,
Binoj
Hello,
Did you try to choose the pen you want just under the type of line into the roof parameter ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
It is not showing line type pen showing for composite roof. For Basic roof the line type pen is displayed.
But I tried the following and it works
"When you change Floor Plan Display from Outlines Only to Projected with Overhead, two more options will appear in the Outlines panel: Overhead Lines and Overhead Line Pen, which control the overhead appearance. Once these have been adjusted, you can change Floor Plan Display back to Outlines Only. This looks like an interface bug, since these parameters control the appearance of the Roof when set to Outlines Only, but are hidden in the panel (they are not hidden in the Info Box)."
Thanks for your help
Kind Regards,
Binoj
