Line weight
I cannot get my true line weights to appear in my layout
I have set the line weight to true weight and saved it as a drafting copy and the true line weights show in archicad but not plotmaker why is this?
4 Replies 4
Eduardo Rolon
There are three types of Pen Settings (Line weights):
1) For Model View
2) For Layout Views
3) Per Drawing
To troubleshoot first check #2 by going to the menu ->Options -> Element Attributes -> Pens & Colors (Layout Views).
Then select a drawing and check what Pen Setting it has.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
unfortunately i have to mention that i am working in version 9 still so the pull down tree menu you broke down for me is not the same I
and I am not sure where the element attributes would be
there are some under the drawings settings but...
never mind i found it it in options/ display options/ line weight/ true weight
Eduardo Rolon
SADSNa wrote:
unfortunately i have to mention that i am working in version 9...
That is the reason that it is recommended to list your AC version and operating system as part of your signature. That can avoid wasted time on a sunday night.
AC29 US/INT -> AC08
