2007-08-1012:57 AM - last edited on 2023-05-2505:55 PM by Rubia Torres
Lines between slab and wall elements in section?
2007-08-1012:57 AM
Is there a way to have lines drawn automatically in section at the junction between the slabs and other elements? Both elements are concrete but they would not be poured at the same time.
The Redlines I have sketched in. I would like black lines to appear in the section cuts/elevations automatically.
You have to use different Cut Fills. If you use the same Cut Fill they will merge together. If you want them to be the same but not merge go to the Element Attributes >Fill Types and copy the fill use one for the wall and the other for the slab.
