Llayout book - my title block & consecutive sheets numb
I know it is so easy that I am blind to it...much like Love, OK
How does one in a step by step way, take my title block as a Master Layout and then input the drawings on sheet 2 ,3 and 4 and have the numbers consecutive...and the title block show on all...?
I've spent 8 hours and 3 books and nothing has worked...so it must be tooo simple...Yes ?
Thanks. Paul
15 Replies 15
Eduardo Rolon
It is called Autotext
In the Master layout, using the text tool (right click), layout number…
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Thanks that clears up lots....however, now how do I get my master layout with the consecutive numbers on all my sheets..... ?
Thanks, Paul
Eduardo Rolon
Once you assign the Master layout to your layouts they will start the numbering automatically. Under Help go to Archicad help -> Index -> M -> Master Layout
AC29 US/INT -> AC08
Thanks but no way does that work on my desktop. I open a layout sheet and up comes a blank sheet...there is not way that I have found to have the title block and numbers show up on any new sheet.... I know it must be simple but I can not find the hows and whys... anyplace... can you ?
Paul
Eduardo Rolon
Under Help go to Archicad help -> Index -> L -> Layout -> Id's -> Automatic Layout Id Assigment…
AC29 US/INT -> AC08
Eduardo Rolon
help
AC29 US/INT -> AC08
Thanks for your explisit assistance....However, the Master Layout that I have created still does not show up on any layout no matter what I do. As I said it must be so simple that my 6 years of college make me miss it all together...
Eduardo Rolon
Grab the master layout and drag it on top of the layout
AC29 US/INT -> AC08
Have you assigned your master to the layout? See image.
(WARNING: I just tried to select multiple layouts in navigator from in the file shown, to assign the same master to each, and AC crashed and bug reporter started, so I would avoid trying to do it this way. This happened twice on different (but similar) files, AC11 1033)
