Load Zone Stamps
Seiss Wagner
I am using STS 8.1 template. I would like to load "Zone Identifier 2" under: Options>Zone Catergories>Load Other Zone Stamp, but I don't know where to find the file. Can someone please point me in the right direction. - Thanks
ArchiCad 21 / OS X 10.13.5 /
iMac 3.2GHz i5 - 32GB /AMD Radeon R9 M390 - 2048 MB/
Dual 5K - 27" Displays
1 REPLY 1
That Zone stamp is in the ArchiCAD Library. It's missing because you don't have the AC Library loaded, which you generally, probably, should. Use File -> Library Manager to load the library from Apps : ArchiCAD 8.1 Folder : ArchiCAD Library 8.1.
You can't load AC Library parts individually, because they are stored in an archive, unless you open the archive and save the parts as a library. IMO, it's better to leave them archived and simply keep the library loaded.
HTH,
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
