Loading and Saving Detail Markers?
I set up a Detail Part Marker NCS, then have been working with the file for weeks. I went back to use it and it is gone. No longer shows up in the selection list - All I have now are Basic - Simple and Standard. My archive file shows additional markers. Cut and paste between plans will not work. How can I get the NCS part back?
If the part is in the loaded libraries then it should appear in the list. If it is not then copy/paste won't work. Are you sure it's loaded?
I didn't see where to load it from, I'll look again tomorrow. Thanks.
