alexliz
MEP Designer 28 - Missing things
I am trying to understand how things work in v28's MEP world. My Archicad complains that these are MISSING:
Branch Preset
Design Criteria
Segment Preset
This is with a New & Reset All... and with the default Archicad 28 Library which came with the Technology Preview. When I add the MEP 28 library, it actually loads the 27 lcf, in case this if of importance.
Has anyone been able to use MEP Designer in 28?
Archicad 29.0.2 (3200) INT; macOS Sonoma
1 Reply 1
Spencer Browne
I had similar issue, and found a resolution in one of the community forums.  It turns out that the MEP environment was missing.  I post a link to the solution that was provided, once I find again.  On a separate note I still cant figure out how to get pipes to slope in 28, but slow progress is better than non right?
