2021-07-22 06:09 AM - last edited on 2023-05-30 02:13 PM by Rubia Torres
2021-07-22 08:54 AM
AdrienneB wrote:If you select several MEP pipes (or all route) you can modify them the way how are describing.
Is there a way to modify a duct (or pipe) route and have it automatically adjust, or do you need to manually modify each piece? For instance if you created a ductwork route and then decided that it needed to jog up at a certain point or one of the segments needed to shorten. It seems like you should be able to edit it more easily and it wasn't just a one and done thing.
