MEP Routing (MEP Modeler)
Is there a way to modify a duct (or pipe) route and have it automatically adjust, or do you need to manually modify each piece? For instance if you created a ductwork route and then decided that it needed to jog up at a certain point or one of the segments needed to shorten. It seems like you should be able to edit it more easily and it wasn't just a one and done thing.
1 REPLY 1
Podolsky
Ace
If you select several MEP pipes (or all route) you can modify them the way how are describing.
