MORPH flexibility
Morph as a design tool flexible and convenient , can it accommodate DOORS and WINDOWS ? And I try to pull out the ( attach ) interface from AC 18 . Could you direct me ?
undefined
1 REPLY 1
This has nothing to do with schedules so I have moved it to the 'Working in Archicad' section of the forum.
Please try to post in an appropriate section of the forum.
No - you will have to create openings yourself, insert a wall and then add a door or window.
Not sure I understand what you want here.
If you just want to find the command then select your morph then DESIGN menu > MODIFY MORPH > MODIFY SEGMENTATION.
Or turn on the Morph tool bar and select the icon there.
You must have the morph selected otherwise this command is not active (greyed out).
