Mac OS X 10.5 Leopard and Archicad?
Can anyone from G_soft say anything assuring about AC11 working under the about-to-be-released Mac OS X 10.5 Leopard?
150 REPLIES 150
Ralph Wessel
Mentor
norbertsf wrote:
Post here if you get this resolved. I am having the same problem with the ArchiCad Exchange ".bundle" on Leopard with Archicad 10 not being recognized. I tried the "copy/paste" fix , but it did not work. Did you resolve it that way?
Where is the 'ArchiCad Exchange' file located?
Ralph Wessel BArch
Active Thread Ltd
I've tried "Import-Export" ( where it should be). File is still named "Archicad.bundle", but the icon has changed. "Kind" also still says "bundle). I may just have to go back to a non-Leopard machine....
Ralph Wessel
Mentor
I don't have an add-on by that name - what does it do? I can take a look at it if you send it to me.
Ralph Wessel BArch
Active Thread Ltd
Ralph,
It's supposed to be "C4DExporter" from Maxon like Owen mentioned in his post. you can down load it directly from here:
http://www.maxon.net/pages/download/plugins_e.html
This one specifically:
ArchiCAD
Update ArchiCAD 10 Exchange Plugin for CINEMA 4D R10
For Mac OS X and Windows 2000/XP (ZIP - approx. 1.3 M)
You end up with a ArchiCAD 10 folder and inside 3 folders (PPC,MacIntel, & PC). The Macintel is the one ending up as a .bundle and unrecognized by ArhciCAD when exporting...
Ralph Wessel
Mentor
If Owen already has this working and is still following this, perhaps he could send a working copy to you? Try contacting him by PM.
Ralph Wessel BArch
Active Thread Ltd
Will try. Thanks. Back on other machine for now.
owen
Attached are the hacked (but working!) Cinema4D Export add-ons (ArchiCAD.bundle) for both AC10 and AC11.
These live in the ../Add-Ons/Import-Export folder
Don't know if it would make any difference but the PkInfo resource i copied for each was from the respective version of the 3DStudio Out add-on.
hope this works for you - i haven't had any issues yet (fingers crossed)
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
Owen,
THANK YOU! THANK YOU! THANK YOU!
It's working in ArchCAD 11! (crossing fingers)
Thanks for posting the file.
Norbert
owen
No thank Ralph .. i had absolutely no clue why i was doing this!
I did a little research on just what a PkgInfo file is and it doesn't seem like much (take a look at whats inside with TextEdit..) other than it is one of two files all application packages should contain in OS X (other being the Info.plist file). Without these OS X may not recognise them as apps - I guess Leopard is a little more strict on this requirement hence why it didn't work but did in 10.4. I love that you can just copy any old PkgInfo file in and have it work. Anyway
cheers,
Owen Sharp
For me Archicad 11(1086 & 975) is not compatible with Leopard.
I have tried both versions on a G4 PPC 1,42 Ghz mac Mini 1 Go.
Impossible to launch the program with plugins DWG. See error report here after
I hope a quick fix ... Leopard is so cool ... this is the first problem I met with !
Best regards.
Mvdp
Process: ArchiCAD [644]
Path: /Applications/Graphisoft/ArchiCAD 11/ArchiCAD.app/Contents/MacOS/ArchiCAD
Identifier: com.graphisoft.ArchiCAD
Version: 11.0.0 (11.0.0)
Code Type: PPC (Native)
Parent Process: launchd [74]
Date/Time: 2007-11-10 16:27:32.202 +0100
OS Version: Mac OS X 10.5 (9A581)
Report Version: 6
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread: 0
Thread 0 Crashed:
0 libSystem.B.dylib 0x91263ca8 __kill + 12
1 libSystem.B.dylib 0x913087b4 abort + 84
2 GS_BSD_Runtime_Mach-O 0x20080fac std::set_terminate(void (*)()) + 88
3 GS_BSD_Runtime_Mach-O 0x20080f40 std::terminate() + 32
4 com.graphisoft.DXF_DWG_Engine 0x31fd67ec ExPPC_ThrowHandler(ThrowContext*) + 520
5 com.graphisoft.DXF_DWG_Engine 0x31fd6330 __throw_vec(char*, void*, void*) + 368
6 com.graphisoft.DXF_DWG_Engine 0x31fd65ac __throw + 176
7 com.graphisoft.DXF_DWG_Engine 0x31f9f820 OdWinDecrypt::rxUninit() + 92
8 com.graphisoft.DXF_DWG_Engine 0x31f9fa90 UnregisterDecryptSupport() + 164
9 com.graphisoft.DXF_DWG_Engine 0x31ebc9dc Common_ACAD::CloseAd2() + 24
10 com.graphisoft.DXF-DWG In-Out 0x0b46c3b8 MyDllTermHookProc() + 16
11 com.graphisoft.DXF-DWG In-Out 0x0b4f1134 DllTerm() + 124
12 com.graphisoft.DXF-DWG In-Out 0x0b4f1028 GSTermImage + 12
13 com.graphisoft.DXF-DWG In-Out 0x0b4f0e8c callatexitfunctions() + 72
14 com.graphisoft.DXF-DWG In-Out 0x0b4f0ef4 gscallpluginatexit + 12
15 dyld 0x8fe137b4 ImageLoaderMachO::doTermination(ImageLoader::LinkContext const&) + 324
16 dyld 0x8fe02df0 dyld::removeImage(ImageLoader*) + 112
17 dyld 0x8fe03128 dyld::garbageCollectImages() + 112
18 dyld 0x8fe0c284 dlclose + 304
19 libSystem.B.dylib 0x9124f96c dlclose + 84
20 com.apple.CoreFoundation 0x94c65fe4 _CFBundleDlfcnUnload
suite: see attachment
