Magic-Wand Polygons onto Zones Using the Stamp
Since this works, it seems obvious, but if it didn't I wouldn't be surprised; lots of obvious stuff doesn't work.
You can magic-wand a zone stamp to place a polygon using the geometry of the zone itself. It works even if the zone polygon is hidden, and saves you the trouble of finding an edge, since zone edges tend to coincide with lots of other stuff. Magic-wanding the middle of a room is often impractical due to interference of other lines.
Handy for finish-floor slabs, lower-the-ceiling-in-one-room slabs, floor material fills, etc. Just make sure your zones are updated first.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
I keep forgetting to point out that this works for roof and fill handles too.
I long ago developed the habit of keeping the roof handles out to the side of their roofs; it makes selecting roofs easier. The magic wand trick is a nice bonus.
James Murray
Cool. Great tips, James. And congratulations on your tech tip award! šŸ˜‰
http://www.graphisoft.com/support/archicad/archiguide/TiponUsingMagicWandonZoneStamps.html
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks, Karl. I need a few more to catch up to you.
James Murray
