Magic wand tool not working
Pulling my hair out trying to use the magic wand tool to give my contour lines a ridge height.
- I have used the mesh tool to outline my site along the boundry lines.
- I then have the mesh selected and the mesh tool selected.
- With the cursor hovering over the contour line i hold the space bar down and left click.
- Magic wand appears but nothing happens.
I have tried to select other things using the magic wand and it will not pick anything up! PLEASE HELP
*I am using archiCAD 19
10 REPLIES 10
NCornia wrote:
Hi Stuart,
Can the user successfully use the Magic Wand command from the menu? Design > Outline Polygon with Magic Wand... If so, then it is extremely likely it is a keyboard/mouse driver issue that is preventing the spacebar-click method from working. I had a Samsung laptop myself with the issue and upon the advice of our developers I plugged in a USB mouse and it worked then even though the touch pad of the laptop would not. In that case it was a Synaptics driver which was causing the trouble. Some Windows computers have a "Tap" option where the user only needs to gently tap the touch pad rather than actually press down to get a physical click. This "Tap" method is not supported in ARCHICAD. Look in the driver advanced settings to disable this function. I hope this helps.
Best regards,
Hi Nicolas
Sorry I haven't responded earlier. Yes, it works from the menu, or with Maciej Zacher's solution using ENTER instead of mouse click. We will check out the drivers a bit closer.
Thanks
