Making super complex walls
Hello, i'm new to archicad and i wanted to know if there's a way to make walls from the shape of this object imported from rhino. Thank you in advance, regards.
2 Replies 2
Hello crimunozv,
Wellcome in Archicad !
Your wall came from Rhino, your aim is to have a wall.
If you are talking about BIM, you only have to add the right classification to your "rhino-wall".
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
We would have to see some Floor Plans and 3D Viewpoints as well to understand the exact geometry.
But Archicad itself has many Wall geometry options so I can imagine this could be done using Double Slanted Walls, for example, which would be great because you could then place Doors/Windows in them.
