Making super complex walls
Hello, i'm new to archicad and i wanted to know if there's a way to make walls from the shape of this object imported from rhino. Thank you in advance, regards.
Hello crimunozv,
Wellcome in Archicad !
Your wall came from Rhino, your aim is to have a wall.
If you are talking about BIM, you only have to add the right classification to your "rhino-wall".
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
We would have to see some Floor Plans and 3D Viewpoints as well to understand the exact geometry.
But Archicad itself has many Wall geometry options so I can imagine this could be done using Double Slanted Walls, for example, which would be great because you could then place Doors/Windows in them.
