Marquee Selection and then show on 3D not working right
Hello!
I hope all the graphisoft community is keeping covid-free. I have a question about a weird Archicad mystery. On a specific file I select an area with a marquee and press F5 to see the selected in 3D. Instead of just the selection I see the whole elements that are in the selection. So instead of ''cutting a slice'' it shows me in 3D the entire element of all the elements that are in my selection rectangle... I am pretty sure there is a reason this happens ( a selection or something) If you could help me with this would be great!!
Thanks!
12 Replies 12
Ode1
Barry, I have another marquee issue you're going to love! Look forward to your response.
Pic 1 = two storey marquee over REAR of building
Pic 2 = after I hit F5 & fit to page
Pic 3 = After I hit F5 again.  Note FRONT of building not REAR???
 Pic 4 = Filter options
Odette Salem
www.virtualhouse.com.au
AC22 AUS . Intel(R) Core(TM) i7-7800X CPU @ 3.50GHz . 32.0 GB ram . 64-bit operating system, x64-based processor
Ode1
Oh and when I put a marquee over the whole building I still only get the front view...
Odette Salem
Are your shortcuts set correctly?
Does the same happen if you use the right click context menu?
Does the same happen in every file or just this one?
If you select certain items, F5, fit in window, does that appear correctly?
