Marquee tool cut in 3D
i've made cut trough the object with marquee tool which can be seen in 3D window. I'm wondering if there is possible to move this cut/section trough the object in 3D window. I think I saw this somewhere, but I can't remember how this can be done.
Hi!
You can set up a cut plane through the elements visible in the 3d window. Press Cmd+Y or Ctrl+Y and drag the cut plane to where you want it and finalise. The cut plane can be moved again if you need to, or added to with other cut planes.
David Maudlin
RokZa:
AC17 introduced Real-time 3D Cutting Planes, perhaps this is the feature you saw.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you for your answers. I'll try your solution khairulfikri.
@David: I think it was AC16, but thanks for the info
