ā2004-05-10
08:10 PM
ā2023-05-23
03:42 PM
Rubia Torres
ā2004-05-10 08:17 PM
ā2004-05-10 08:39 PM
Matthew wrote:My actual slabs at each floor is the foot print and inside this other enveloping slab, which extends from floor to floor. The outer surfaces of this enveloping slab represents the exterior skin of the building. Which following Carving out these enveloping elements in 3D I can trace them for creating actual walls, Objects and roofs at each floor.
What do you mean by "enveloping" slabs.
ā2004-05-10 10:05 PM
ā2004-05-10 10:17 PM
Matthew wrote:How about using Mesh tool as the enveloping element for massing purposes?
I recommend against the overlapping slabs.
ā2004-05-10 10:29 PM
ā2004-05-10 10:41 PM
ā2004-05-10 11:13 PM
Matthew wrote:Good catch Matthew, "schematic design (and perhaps beyond". As the next post mentioned SketchUp is a good way; I have it and love it But I was at Eureka seminar presentation. They actually created a massing of building and saved it as a modeling plan then worked on the current file, adding elements and detailing it. When a new design idea came to them, they went back to the massing model make the changes and copy paste the changes to the main plan. As the result the design could change with out going back and forth between different programs (SketchUp) and detailed plans would stay intact and up to date.
I assume that what you want is to continue to maintain the massing model through schematic design (and perhaps beyond?).
ā2004-05-10 11:22 PM
ā2004-05-11 07:50 PM
