Merging other files into one
So I've downloaded ArchiCAD 22 and have been making separate files for each section of my project. When i merge other files with the main one, the file shows a grey 3D model without the colour and elements. If there's a solution to showing the colour and elemnts can you please let me know.
Thanks
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Nicholas,
Thank you for the question!
I have a hunch that the merged file is using the wrong attributes inside the main file. Could you merge the "grey" file into a brand new file and see if the issue persists there. If yes, could you share with me the problematic file for further investigation? Let me know if you'll need a secure link to send the file!
Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Carstenem
Try not to use merge but copy and paste. This way the attributes/materials/colors will be "pasted" too.
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
