2020-07-08
06:47 AM
2023-05-25
04:52 PM
Rubia Torres
2020-07-08 09:04 AM
mnguyen wrote:
Hi Chris,
It turned out that this is a limitation with how we present lines of adjacent element in sections. We keep only the thicker or continuous line when 2 lines are above each other in section. Due to graphic override, the line of the thicker element (which is the wall in this case) is delete. Show skin separator would make the line visible again, but so do all the skin lines, which is not favorable here.
Because of this, I suggest a work around for this situation:
- Set the cut line of the wall in the Wall selection settings with a pen thinner than the Mesh's cut line pen
- Use Graphic override and make sure that the Wall's line pen is overridden with a thick pen
Although this will make the mesh cut line thicker, this will ensure that the separator line is not deleted by GO rule.
I hope this will help you with the issue. Should you have any further questions, feel free to ask me again!
Best regards,
Minh
2020-07-29 06:09 AM
