Metal Panel between two windows
dcerezo
Hey guys,
Still new to Archicad so I'm wondering how to do this. I want to draw a wall, say with a stucco exterior material. Then I want to place two windows a few feet from each other.
Now, here's the hard part (for me at least). I want to change the stucco between the two windows, to a metal panel material. three area above and below the metal panel is still to remain as stucco.
How can I achieve this?
ArchiCAD 26 - iMac 27, Late 2019, 3.7 GHz Intel Core i5, 32GB Ram, Radeon Pro 8GB, macOS Sonoma
3 REPLIES 3
The easiest way would be to draw a morph between the windows in an elevation view, and SEO out the stucco, if you wish. https://youtu.be/MnDaOYtoGc4 for a similar example by Eric Bobrow.
Richard
AC26 (since AC6.0), Win10
dcerezo
Thank you Richard. I'll check it out.
dcerezo
Perfect! That video definitely helped.
