Missing Navigator
The mini navigator and navigator palettes have disappeared from my work environment. They are checked in the palette menu (uncheck and re-checking produce nothing). Clicking the toolbar at the bottom left of the active window does nothing and i've checked and made sure that the auto-hide function isn't active (although I should still be able to bring it up). It will come up when placing drawings in the organzer but that's about it.
The navigator is there in the standard work environment (but that totally negates everything else I've set up).
It's looking like a system problem but I could be missing something.
Any help with it's reappearance will be appreciated.
I still do not know where the navigator went in my prior scheme but I solved this one by bringing up the standard palette, modifying it and then saving it as a new scheme
