Learn more
Missing Object
I cannot Find how to get rid of this missing Beam from my library loading report.
I have deleted all beams in the project and it's still there.
Please help, I have read through an older post and tried all the suggestions but the find and select keeps coming up empty handed.
Please help.
3 Replies 3
I am guessing from the name of the object that it may not be placed in the plan.
It could very well be in an elevation, section or detail.
If that is the case then using Find & Select will not find the object unless you have that view open.
As soon as you open the view you should see a red dot where the object is supposed to be so you may not even need F & S.
Make sure all your layers are turned on as well.
THANKS BARRY,
IT WAS A TINY GREEN DOT IN A DETAIL
Ah I think the pen colour must be related to the pen number 1 colour.
Anyway you found it which is really all that is important.
