Read more
Missing Railing in hotlinks
Verginia Pozneac
Graphisoft Alumni
Graphisoft Alumni
Affected version: 21 | Severity: fixed | ID: 229227
Issue:
If a Railing is associated to a Hotlinked Element (in A.pln), it will work correctly in the file where it was created (in A.pln). In case that you place this file in another project as a Hotlink (in B.pln), the Railing will be missing.
Cause:
Railing elements should not be associated to Hotlinked Elements, but currently it is possible. We do not recommend to use this workflow in the meantime, because it can lead to missing elements.
Solution
  • do not place associative Railings on Hotlinked Elements, use Static Railing instead
  • include the Railing in the 1.mod, instead of placing it in the A.pln.
wp-content_uploads_2016_06_Info_18x18.png NOTE: This issues has been fixed in the Updates of  ARCHICAD 21 (build 60xx). Click here to download the latest Upadate.
Comments
Liqiang Lu
Hotlink  needs  Edit mode like  Curtain Wall
Browse more articles
Back to articles
