Missing line of intersection between objects
thank you for the answer.
IC
4 Replies 4
Erich
Just a guess - your roof is continuous through your chimney. You have two options.
1. cut a hole in the roof for the chimney to pass through
2. use SEO to remove the roof with the chimney as the operator and the roof as the object.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Dwight
While some other applications seek out and represent every edge, in Archicad, merely colliding two elements doesn't make an intersection.
Even though it photo renders correctly most of the time, you still need to assert where edges happen as Erich instructs.
Dwight Atkinson
Chimney might not be enough. It will leave roof surface inside the chimney. ;D
Thank you for the reply. I found it more practical to use the SEO function.
IC
