Missing pet palette
For some reason, my pet palette simplily disappears. whenever i click on a element, the pet palette will appear and disappear in a second. i have to click the element, hold down my mouse click and try to choose from there, anyone know a solution?
thank you
5 Replies 5
Dwight
Try an ArchiRestart.
Dwight Atkinson
thank you
Is it possible that when you click the Pet Palette appears but then it immediately jumps to its preferred position which is at some position on the screen that is not easy to notice? I had one time AC Window appearing the right half of my screen and the Pet Palette jumped to the left half, way out of the boundaries of the ArchiCAD Window.
In the Work Environment you can control this behavior of the Pet Palette.
Anybody figure this one out? I have restarted and even applied the standard work environment and it keeps happening. Any other suggestions?
David Maudlin
New to this:
You could try going too the Work Environment > User Preference Schemes > Pet Palette movement: and changing this to Follow Cursor and minimizing the Distance form Cursor to see if that helps.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I found that using the 'New and Reset all' and Options>Work Environment>Enable All information messages' fixes this, the next time you open ArchiCAD the issue is gone.
